Wheel stud size help
Could someone help me with what size lug nuts i need for a 75 highboy. Looked it up and must have got the wrong information. Thanks
Should be 1/2 x 20 for threading.
Are you asking about the stud size or lug nut size? The studs will be 1/2 X 20 BUT the serrated part of the stud will vary in diameter depending on whether or not the vehicle is 1/2 ton or 3/4 ton. The length of the stud will also vary, depending on application. I believe all lug nuts will be 1/2 X 20.
Rock Auto shows the different applications, based on size of truck.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
Front: 8D-1107-A .. Stud = 1/2" -20 x 1 3/4" long.
Rear: D2TZ-1107-A .. Stud - 1/2" -20 x 2 1/6" long
