whats the biggest tire a stock f150 can run?
Mr. Stroker
CASE IH
3,121
67
Michigan
Spring sag maby? No difference in suspension from mine to any other 150 or bronco with quad shocks.
Mike, usually the first place the 33's rub is the radius arm. I know you said yours didn't and I don't know what the differences are from Bronco to F-Series, but the spring sag isn't usually the problem.
Mr. Stroker
CASE IH
3,121
67
Michigan
maby my radius arms are bent inward? LOL
My dad had some 31" BFG MTs that rubbed, and they were 31s. The Yokohama SuperDiggers didn't, and neither does the Michelins on it now. 31"s are the optimal size for a non lifted truck.
Mr. Stroker
CASE IH
3,121
67
Michigan
Ok, but does anyone with 33's have the factory style wheels? Must have something to do with backspacing on aftermarket rims??
old thread, new pics.
here are the tires mentioned on page 1
and how it used to look (gross)
i guess i can't bump this thread and not mention performance.
it's worse. gas mileage has always varied so much that's it hard to give an answer on that. the last tank or two seems better, but nothing astonishing.
it is worse on hills on the highway, but with the amount of towing i do (virtually none), it's fine by me. if you're looking at changing tire sizes and don't mind a very slight loss in performance, this is a good size
What size is that there? My mileage is okay with 31"s,,,,
hmmm, guess i never updated this thread with the tires
265/70/R15
Dunlop Radial Rover AT
265/70/R15
Cool, so that's about equivalent to a 30"? They dont look bad on your truck. :)
What gear do you have in the rear end, Tom?
pretty sure my vin/door code said something like 3.53 or something even numerically lower, but my rpms are at 1900 at 67 mph. that makes me thing it's been swapped to either 3.73 or 4.10 at some point. the PO bought this strictly to tow a 5th wheel (that's why the miles are so low). i can't imagine buying it and keeping low gears in it to tow with.
EDIT: long story short - no idea
1900 at 67 don't sound like 4.10s to me. Maybe 3.73s...lemme find some numbers and do the math.
I have 3.55's and at 67 I'm pulling around 2200.
That means you have a lower numbered gear. I'm not even sure what gears there are (numerically) lower. I know there's such a thing as a 2.93 and I think a 3.07. Is there an intermediate that was an option?
^^I think it was a 3.08 not 3.07...but IIRC, there's also a 3.23.
Your automatic may have a different OD ratio than his 5-gear, though...
