what is this?
Anyone know what this item is called, and about how much they run? Mine is taped together, hanging out loose, and just needs replaced.
Thanks
jebadiah04
Rooster Snorkler
849
27
I do not know what its called but usually the plastic pins that hold it on are what is broke.
Its just a wire holder not real important.
The pins you can get at any body shop the big part is probably ford specific
Sent from my mudwhistle via lemmiwinks.
Jeb is right. The wiring harness goes across the cowl, and that piece routes the wiring away from the heat of the turbo (thats why the holes are in it, to vent the heat). Usually, the "ears" that are push pinned to the cowl are what breaks.
jebadiah04
Rooster Snorkler
849
27
Btw that tape on the right and left is factory :)
Thank you all for your input! I'll leave it be, as my 'limp-home' wrench came on yesterday... New post, here I come!
