what carb should i use?
wildpony1986
Georgia Chapter member
93
Senoia
i have a 1977 F-100 with a 302, edelbrock 289 series intake mild cam full length headers and i just dont know what carb i should use to get good power but still get decent gas milage?
5-600 Vac secondary carb and how much you have your foot in it will have a lot to do with your fuel economy.
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
good power and good gas mileage just doesnt goes in the same sentence .. but yeah an eddy 600 vac sec will be good :)
oh and welcome :D
does it matter what brand?
Not really..Holley and Edelbrock are the most common...there is Barry Grant (speed demon), Pro-Systems etc...comes down to what you want to spend and how comfortable you or your tuner is with a particular brand.
wildpony1986
93
Senoia
thats the reason i said decent...which means more than 5 miles to the gal
A quick calculation shows that a 302 running at 85% VE would require a 450CFM carb...at 100% VE it would be about 525 CFM...don't oversize the carb.
SuperCab
547
Montana
x2. A bigger carb is not better, especially on a smallish engine like your 302...
600 would be too big imho....
1977 ford f-100 style side
302 smallblock
c-4 tranny
1986 mustang gt
Welcome! :wavey:
I would agree with what is previously stated. No more than 600 or so.
Btw- ford doesnt classify engines by big block/small block. there are engine series. smiliehijacked
if you go 4bbl you should have a 4bbl intake and heads.
otherwise a 500cfm 2 bbl would be max.
it is the air and compression that makes power. the engine in stock form can only burn so much fuel
A smaller 4 barrel will keep the air/fuel velocity higher than a large 2 barrel...which will result in better atomization. Using a 4 barrel carb will not mean that you need 4 barrel heads....a 4 bbl 351 head would be nearly useless on a truck unless you are going to be turning 5000rpm+.
That's right, It depends on the application
2bbl = more torque at bottom end
4bbl = more HP at higher RPM
Hmmmm, What do you really want to do with this engine and/or willing to sacrifice ?
How are you arriving at that conclusion Dennis?..specifically the more torque with a 2bbl part of that statement.
SuperCab
547
Montana
It may also be worth while to mention that a 500cfm 2bbl and a 500cfm 4bbl do not flow the same volume.
CFM is measured differently between 2bbl and 4bbl carbs...
Probably from a U-haul truck...that would explain the govenor.
wildpony1986
93
Senoia
i have a new edelbrock 289 series 4bbl intake and it has 4bbl heads...thanks for the info
