F 150Cobra
"Wild HoRsE" Got Torque?
i passed this simester and dad is happy so he is sponsering the rest of the last last order i have to make for the truck to get finished
these things
Gauge Pod, Dual 2 1/16 in., Black ABS, Ford, F-Series Pickup, Each $29.95
ATM-5721 Gauge, Phantom, Oil Pressure, 0-100 psi, 2 1/16 in., Analog, Mechanical, Each $46.95
ATM-5737 Gauge, Phantom, Water Temperature, 100-250 Degrees F, 2 1/16 in., Analog, Electrical, Each $45.95
CCA-503-16 Valve Stem Seals, Teflon®, Positive Stop, .530 in. Guide, 11/32 in. Valve Stem, Set of 16 $21.95
CCA-740-16 Valve Spring Retainers, Steel, 10 Degree, 1.500 in. Outside Diameter, .690 in. Inside Diameter, Set of 16 $51.95
FLX-5560 Fan Clutch, Standard Thermal, AMC/Ford, Lincoln, Mercury, Each $46.95
(can i use the i6 fan for the V8 ?? )
FMS-M-9600-A302 Air Filter Assembly, 13 in. Diameter, Round, Steel, Chrome, Ford Racing Logo, 2 3/4 in. Filter Height, Each $41.95 $41.95
HLY-20-88 Throttle Cable Bracket, Steel, Chrome, Holley, 4150/4160, Each $21.95
MOR-74130 Switch Panel, Aluminum, Black, 4 in. Wide, 5 in. Tall, 3 Toggle Switches, Each $49.95 $49.95
RNB-CS37897 Clutch Slave Cylinder, Ford, Mercury, Car, Van, Pickup, SUV, Each $129.95 $129.95
ZZZ-HP48-1 Clutch Kit, KEVLAR®, 1 1/16 in. Diameter Shaft, 10-Spline, 10.5 in. Diameter Disc, Ford, Mercury, Kit $279.95 $279.95
and engine mounts and perches from a buddy of mine that has a junkyard
about 1000$ in parts i saved about 700$ but dad is sponsering the rest
these things
