VID of the i6 300 running..
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
did a cap rotor, sparkplug wires change, and the O2 sensor.. running better
bit still not perfect.. i think its just need some driving.. maybe the injectors are dirty..
Nice job, Jurgen. That thing looked a little rough with the 4 flats. :p
F 150Cobra
3,642
104
Aruba
pullution pump pully is my guess.. for that wistling
wuaahah.. ever heard of, dont judge the book by its cover?:)
it revs fine.. but the idling is like rough.. it shakes the car while idling.. what could that be?
maybe the sparkplugs? havent change them yet..
F 150Cobra
3,642
104
Aruba
nope.. these uses a bigger thread plugs.. i had a set of the v8 i had and tought i could use them but these are bigger thread.. soo i have to wait till monday
radialarm
Clown of Death!
Sounds pretty good to me :) What's that whistling noise?
HAHAHAHAHA!!! I figured it was a turbo or part jet.:rofl2:
Jergen, that's pretty good for a truck that hasn't run for 4 yrs. Injector cleaner, two words get some.
Sweet brother. I want to see you drivin it now.
Brakes are over rated. I drove to my job and to the parts store the back to my job with the brake line blow out. I just stay back and give room to slow down. I had like a week where every line was blowin out on me and i just got sick of it and changed them all.
F 150Cobra
3,642
104
Aruba
hahaah this doesnt have any brake pressure the brake tubes that connects the the drums in the rear are rusted and has holes..so it squirts the fluid out from there.. lolz
Mine was like that and it still had some pressure for the fronts. Id take a quick trip around ur block or out the driveway so you can see how it rides and if the clutch and drivetrain work good.
F 150Cobra
3,642
104
Aruba
yepp i guess ill do that.. after i get some tires lol.. 2 tires wont hold air.. 2 are good i wil get some 2nd hand tires for meanwhile.
Mine was doing that for the longest time, turns out it was the alternator squealin'. Who knew... [confused]
F 150Cobra
3,642
104
Aruba
ohh really? how did you fix it?? take it off lubricate it?
Prob change the bearing in it. Id just get a new one for it. Id take the belt off and spin everyhing and see if anything feels rough or makes the squeek, then you will know. Might just be the belt from sitting.
No, the old one died, and Motorcraft couldnt find the right part, so I got a Napa Auto Parts one. The squealin started, and I tried a new belt, belt dressing, even a new auto-tensioner, and it didnt do anything. Finally after I left my lights on (like an idiot) it wouldnt stop squealin (because the alternator was doing extra work and didnt shut off). So I took the alternator back, and got a replacement which is working great. :)
Yeah, make sure all the pullleys are tight, the auto-tensioner is working, and the belt isnt getting bound up. You could just try a new belt, and belt dressing and see where that gets you. :)
F 150Cobra
3,642
104
Aruba
ahh leave the crap alone.. untill it stops chargin.. then ill get a new one..
yup, battery is probably pretty low after not being run for a while, and alternator is working overtime. :)
It only squealed when the alternator was on, but ideally it shouldnt do it at all. ;)
