Hey fellas...I have what I think is a vacuum issue in the 400 in my Bronco, not big...but annoying enough. It may even be cam related since I went bigger than stock. Anyway, on a fresh start up (hasn't run in a while) at high idle in park, no issues...but when I knock it down (and choke wide open, cuz it's 80+* all the time) and put it in gear, the thing idles really rough and doesn't really wanna run (might even have a small miss). I have to keep my foot on it a little to keep it running...and the brakes are spongy. However, after driving for a little a bit and I come to a stop, it idles perfectly and brakes are back to normal. But if I leave it sitting or idling, it progressively gets worse again until it is driven or starts pulling vacuum. Now I've double checked, triple checked and quadruple checked intake bolts, carb to intake and some of the vacuum lines.
So does anyone have any potential suggestions? I didn't think my cam was radical enough to cause an issue like this...is it? Is it possible a leak in the booster could cause all these issues? I was reading through my Ford manual and in the trouble shooting section, it said a bad PCV valve could cause these symptoms.
Thanks in advance.
Thanks in advance.
