- Moderator
- #1
you could run a balloon test but have fun getting to the fitting under the turbos.
subscribingTruck develops aeration in the fuel. After driving, park it on an incline with the driver side down, it won't start. Bleed the system, it starts (until you park with driver side down). The high pressure side always has bubbles in the fuel. I'm thinking combustion is getting past the washer at the bottom of an injector. Looks like #2![]()
The 6.4 essentially IS a 6.0 with a few "hang ons". Same block, close to the same heads. The electronics are the major headache.The more I read about these engines, the more I think they are total garbage..
The deal is, you don't read about the ones that are out there running flawlessly day in and day out.
With much less issues than the 6.0 I don't see the basis for this statement?The more I read about these engines, the more I think they are total garbage..
Vince, how many cabs have you had to pull off of 6.0 vs 6.4 trucks?The 6.4 essentially IS a 6.0 with a few "hang ons". Same block, close to the same heads. The electronics are the major headache.
Bingo......The deal is, you don't read about the ones that are out there running flawlessly day in and day out.
Here, neither diesel has been the problem children that you hear of elsewhere. I think its been 5 6.0, and 3 6.4 (one of them twice).Vince, how many cabs have you had to pull off of 6.0 vs 6.4 trucks?
Those virtues however are leveraged with a truck that is paid for.....
