- Moderator
- #1
Went to the wreckers and found the factory under hood light option. Tested the unit and it works fine. (has the complete harness and plugs, etc.) My truck has the green wire on the drivers side firewall with the plug were you get the 12 volt supply, but there is no power to it. This is where I'm stuck. All fuses are in place and not burnt out, have a good ground and the grounding strap is on the hood/firewall. I used a jumper wire direct from the battery and it works great. So how come no power to the factory plug-in
