Turn indicators don't work
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
changed flasher but still nothing
when the flasher is bad does the turn indicators on the dash work ??
mine does nothing! no indicator on dash or nothing! is there a fuse? i dont have the fuse box diagram anymore thats why
or is the thing on the column bad??
thanks!
primetime
sawmill slave
1,495
64
Onaway Michigan
Turn signal fuse-From the upper left corner of the fuse block, second over (to the passenger side) and second down (towards the floor). It`s 15 amp. The fuse block is the same from 87-96, and a lot of the cars of this era. Find an owners manual and see if the picture matches your fuse block.
If you need a pic, let me know, I`ll do it tomorrow, it`s a 45 minute deal for me to load a pic, and I`ve got a hankering for a bar burger tonight.
If it's not the fuse, then the turn signal switch will need to be replaced. If you have a tilt wheel, then the end connector will have to be separated so the wires can be threaded through the column, then reconnected. I just did this on my '89. Same symptoms as what you described.
Below is a link to the thread that I posted about the problem, with some help from dustybumpers.:D
http://www.fordtruckfanatics.com/forum/showthread.php?t=32143
