Try your knowledge
If you have a misfiring plug will your o2 sensors show rich or lean?
  • rich
    Votes: 9 64.3%
  • lean
    Votes: 5 35.7%
  • Total voters
    14
  • Poll closed .
If you have a misfiring spark plug, will your o2 sensors show rich, or lean?
slmann
232
Festus, Mo.
that's what I went with too. but I'm just guessing.
good post Vince. You gonna school all of us here?
I just want to hear all of the gears turning! There's a lot of these examples out there that are maddening!
I voted lean. computers these days sense the misfire and turn off the injector, but the cylinder is still pumping air. 02 senser has a certain volume of air passing that would show lean because of the dead cylinder.
Even my old van ran pretty good with one plug wire off!
mrxlh
Oilfield Trash
5,904
430
Stigler, OK
Rich, still getting fuel, and not burning it. (unless the injector is disabled by the mis-fire code, which in that case it would lean it out) Depending on how loaded the engine is, it will also show detonation and a lower % level of free oxygen in the exhaust as read by the O2 sensor nearest the cat. So when do we get the answer Vince?
Bob Ayers
North Carolina Chapter member
1,474
111
Durham, NC
I voted lean due to the O2 being dumped into the exhaust from the misfire.
I would say it depends, not enough info. If it is the fault of the plug/wire that it is misfiring, rich. If it is the fault of fuel supply or other issue, lean. Also, if the misfire is due to a mechanical problem, it can go lean or rich.
OK, I kind of think this one is going as far as it will ever go! LEAN---the reason, O2 sensors measure oxygen, not fuel. Oxygen is consumed during combustion, no spark, no combustion, excess oxygen in the exhaust flow.
I think it will always read LEAN in rattlecan's truck; He's so broke he even makes the truck starve!
