89frankenford
Grabber Green Consultant
well on my way from work tonight my transmission pretty much said.."I GIVE UP". it still works but BARELY. basically whats happening is when i start it up and put it in 1st, i let the clutch out and it shutters like CRAZY! the entire trucks shakes like a bastard. i put it into 2nd..same thing...now it only happens when the clutch is being released. not when its in gear or out of gear.
the other odd part is that when driving i come to a light and i have it in nuetral it will stall because its "in gear"...this happens every other time or so. tomorrow im buying 5 qts of ATF and dumping it in the tranny because i know its low..
WTF is going on? is this a tranny issue or a clutch issue? i checked the clutch fluid and topped it off but its still doing the same thing. also the input bearing is a bit louder now.. i thought i smelt a hint of ATF in the air but that might have been me just dreaming it up being that it was 1230am
