Rebuilt C6 transmission and new converter, do I just put in the fluid make sure it is in park and crank the motor or is there a better way to do it. All the ones I have changed still had fluid in the converter. thanks
Put a few quarts in before starting it, then it will pump it into the converter on its own. That way it isn't starting dry. I forget how many a total fill is on those. Probably should be safe with a 4 quart prime.
By all rights the convertor should have had a quart dumped in it. A c-6 should take 11 to 13 quarts depending on whether its 2wd or 4wd. That`s from a dry fill.
ive always poured in 4qrts in a dry setup then start the vehicle,once i get about 9qrts in ill start shifting it out to workout air,going from reverse to drive several times with my foot on the brake & fill to full & repeat process & check the level.
