- 2
- 0
Got the 04 back from the shop today after some minor work but while it was there we discovered to my dismay the transfer case is pretty much shot.
Would this cause issues when turning? We had started to look into a groaning noise every time its turned to the right normal and clunking (Supposedly normal) when turned all the way over.
Driver side cv joint was just replaced so we checked the passenger side and it did seem to have some play but I'm thinking cv joints are supposed to have some play as it clicked and moved very little. Should I replace it?
Also seemed odd when jacked up and in gear the passenger wheel could be held still and tends to sit there and jerk slowly unless gas was applied. Maybe its a Limited slip thing tho.
Anyways looking at a junkyard case with 75k on it. Anything I should do to it before I have it installed or make sure I get a specific version?
Found a video on youtube that shows what the front passenger wheel was doing.
https://www.youtube.com/watch?v=zoCjX5Btp80
Thanks
Thanks
