tranny temp gauge; language problem...
Ton van der Sluijs
official Lucas dealer
Good morning everybody:)
I've acquired an Autometer Tranny temp gauge... I do understand the wiring scheme for 90%:headbang:
They say, black; to the neg. ground of the battery, that's simple.
the red one goes to the "contactlock" (sorry, I do not know the American word)
in the steeringcollumn , a connector to the sender is alright with me.. But... they wrote, a white one goes to the "Dash"... I think, a place somewhere in the dashboard, but can some one tell me were in the dashboard? could it be a + point, were is constant electricity like one of the wires of the radio, so that your radio gets power without the key in the contactlock?
best regards Ton van der Sluijs
I would think that the "contactlock" would be a switched power source from the ignition,(key). And the "dash" would be a not switched or always has power source, with fuse.
Ton van der Sluijs
Hi Mark:)
Thanks for your reply. That's right!! I meant the ignitionkey!! I was forgotten that totally. Here we name the ignition key "contactslot" and I uses and very exact translation; "contactlock". You confirmed also the right way to connect one and other.
Best regards Ton
primetime
sawmill slave
1,495
64
Onaway Michigan
The white wire is for the light in the gauge. I hook it to the running lights so that the gauge light comes on when you pull out the light switch. I don`t know how or if you can hook into the dash lights so the gauges dim with them.
And yes, the red wire should hook into a key on ignition source. I generally unhook the connector for the key in ignition/door open alarm. I put a male spade on the wiring for whatever I want to power and plug it into the key chime connector. Solves two problems at once if you know what I mean.
