I just purchased a 1989 F-250 4WD with ABS. The vehicle came with a Drawtite Activator II brake controller already installed. I was checking the wiring and voltages at the plug at the rear of the truck, and I have a constant 12 volt signal coming from the blue wire(trailer brakes) without the brake lights on. After finding the wiring instructions on the good old internet, I discovered that the wiring connections on the truck were not correct.
The instructions say NOT to connect the red wire on the brake controller to the cold side of the brake pedal switch on 1989 - 1991 fords with ABS, but rather connect to the brake wire going to the multifunction switch.
My truck was wired to the cold side of the brake pedal switch. Can somebody tell me why the wiring is different on these vehicles with ABS? I am assuming the brake controller is fried inside because of the incorrect wiring?
I posted this question here because of the vehicle-specific directions for these fords. If the moderator feels it belongs in the trailer section, feel free to move the question to that section.
