To overdrive or not to overdrive
1994 F150; 6 cyl; automatic; 143k miles... I use my truck without a heavy load in the back most of the time and drive in town and on the road. Occasionally load it up with a half ton + of lumber, wood, gravel, etc. but not often. On a daily basis should I have the Overdrive on or off? What's the advantage to each? Thanks.
The overdrive's advantage is obviously fuel economy. If you are driving around with no load, I wouldn't worry about it.
I'd shut overdrive off if I was hauling a heavy load and found my transmission constantly hunting between 3rd and OD. The idea is to minimize transmission wear.
Running O/D with a big load also causes excessive heat. Heat=death for auto trannys.
polarbear
just growing older not up
12,878
607
Boring, Oregon
93 F150 4X4, 5.0, 4EOD. 232,000 miles when sold.
95 F150 4X4, 5.0, 4EOD. 274,000 miles.
'01 Grand Marquis. 207,000 miles.
ALL of them had/have the original transmissions. The trucks haven't been used gently. I never drive with O/D enabled unless I'm consistently going over 55-60 mph. Go to "OD off" on long climbs, or any situation where the transmission starts to "hunt" for a gear.
This isn't true of the newer Automatics. Newer 4/6 spd. Auto's get slapped in "D," and always seem to know what gear to be in.
