thoughts on a truck like this?
Buddy of mine just got serious about replacing his current ride ('07 Escalade) and he's thinking about a 3/4 ton diesel pickup.
This one I just pulled off AutoTrader, but it's about as close as I've seen to what he's looking for. (Right color, right cab/bed, right powertrain, etc.)
Thoughts on these trucks? Primarily as a daily-driver, but he does want to be able to pull 10.5-11k on occasion (hence the fullsize diesel).
If history is an indicator, he'll probably hang onto it for a couple years, and dump it after 40-50k miles when he gets bored and a few big repair bills start looming.
2008 F-350 Supercab Longbed
My brother has had very few issues with his 6.4L and seems to very happy (63k miles on it now). My only gripe with that truck is that it was topping out at 15 mpg right from the factory. And that's driving very conservatively. He doesn't worry about the mileage but make sure that your friend isn't worried about it either. His is a crew cab long bed 4x4.
Good number to know- thanks!
He's not overly concerned about MPG, but at 25k+ a year, I have to imagine its a significant line-item in his budget.
Lost
PA Chapter leader
3,288
central PA
If you saw the Ford mechanics standing on their heads to work on them You 'd buy something else . Even stuff on top motor takes hours to get to . And at 6 to 10 trucks a week with issues in that garage and I live in woods. I wont buy one.
Standard Claims List For Model Year 2008
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTWX31R78ED84037 T/F7 F T/BD T/CD T/E A1 T/BE T/QL 02-APR-2008 05-DEC-2008 111556 USA 0 1F01 030301 * 8009 * L87 53 13
AWS Claim Key: 1731872 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03636 - * Name: FREEDOM FORD, INC. Ph: 845-8311400 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:01-OCT-2008 Doc #:020313A
Cust Comments: PERFORM 08T01
Tech Comments: RADIATOR VENTURI TEE INSTALLATION 08B06
1FTWX31R78ED84037 T/F7 F T/BD T/CD T/E A1 T/BE T/QL 02-APR-2008 05-DEC-2008 111556 USA 0 2G01 * * * * * * 14
AWS Claim Key: 1804233 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03636 - * Name: FREEDOM FORD, INC. Ph: 845-8311400 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:14-OCT-2008 Doc #:020528A
Cust Comments: PERFORM RECAL 08B07
Tech Comments: RECAL MULTIPLE MODULES
1FTWX31R78ED84037 T/F7 F T/BD T/CD T/E A1 T/BE T/QL 02-APR-2008 05-DEC-2008 111556 USA 4 7M01 150102 * 18C869 * A04 42 3637
AWS Claim Key: 3050058 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08956 - * Name: MEREDITH MOTOR COMPANY, INC. Ph: 603-2794521 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2009 Doc #:04614304
Cust Comments: CD PLAYER INOP SIRUS STATIONS DONT STAY PRESET
Tech Comments: REMOVE UNIT AQUIRE NUMBER REINSTALL WITH NEW UNIT
1FTWX31R78ED84037 T/F7 F T/BD T/CD T/E A1 T/BE T/QL 02-APR-2008 05-DEC-2008 111556 USA 4 7S11 180107 7C3Z 14489 AA B63 30 3637
AWS Claim Key: 3050057 Trx Code: 2 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08956 - * Name: MEREDITH MOTOR COMPANY, INC. Ph: 603-2794521 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2009 Doc #:04614302
Cust Comments: TRAILER CONNECTOR WONT CLIP IN
Tech Comments: MTIME TO REPLACE NO PUBLISHED LABOR OPERATION
1FTWX31R78ED84037 T/F7 F T/BD T/CD T/E A1 T/BE T/QL 02-APR-2008 05-DEC-2008 111556 USA 4 7M01 150102 8C3T 18C869 EC A07 42 3637
AWS Claim Key: 2993706 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 67803 - * Name: FORD COMPONENT SALES, LLC Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2009 Doc #:02197909
Tech Comments: Dealer RO# 0 1878# A0288469
1FTWX31R78ED84037 T/F7 F T/BD T/CD T/E A1 T/BE T/QL 02-APR-2008 05-DEC-2008 111556 USA 4 1F01 * * * * * * 3637
AWS Claim Key: 3050056 Trx Code: 08B06 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08956 - * Name: MEREDITH MOTOR COMPANY, INC. Ph: 603-2794521 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:09-MAR-2009 Doc #:04614301
Cust Comments: 08B06 COOLING T RECALL
Tech Comments: COMPLETED PART ALREADY INSTALLED
1FTWX31R78ED84037 T/F7 F T/BD T/CD T/E A1 T/BE T/QL 02-APR-2008 05-DEC-2008 111556 USA 6 6P07 010301 * 3820124 * B15 07 6451
AWS Claim Key: 3486247 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08956 - * Name: MEREDITH MOTOR COMPANY, INC. Ph: 603-2794521 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:11-MAY-2009 Doc #:04717701
Cust Comments: LEFT FRONT DOOR DOESNT CLOSE CORRECTLY
Tech Comments: ADJUSTED LEFT FRONT DOOR HINGES AND STRIKER
1FTWX31R78ED84037 T/F7 F T/BD T/CD T/E A1 T/BE T/QL 02-APR-2008 05-DEC-2008 111556 USA 6 7S02 180102 * 14401 * A07 X1 7588
AWS Claim Key: 3664406 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08956 - * Name: MEREDITH MOTOR COMPANY, INC. Ph: 603-2794521 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:02-JUN-2009 Doc #:04757301
Cust Comments: RADIO INOP NO POWER WAS REPLACED AT 3687 MILES
Tech Comments: CONFIRM RADIO INOP CHECK TSB AND SSM FOUND SSM 20713 CHECK FUSES FUSES GOOD RADIO STILL INOP REMOVE RADIO CHECK WIRING CONNECTIONS CONNECTIONS GOOD REINSTAL RADIO RADIO WORKS ALL FUNCTIONS OPERATING
1FTWX31R78ED84037 T/F7 F T/BD T/CD T/E A1 T/BE T/QL 02-APR-2008 05-DEC-2008 111556 USA 9 2G05 031405 * RECAL * D50 04 11047
AWS Claim Key: 4240540 Trx Code: 2 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08956 - * Name: MEREDITH MOTOR COMPANY, INC. Ph: 603-2794521 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:27-AUG-2009 Doc #:04904202
Cust Comments: HAD LARGE PUFF OF WHITE SMOKE OUT OF TAILPIPE
Tech Comments: CHECK TEST AND DIAG PER TSB 09 06 07
1FTWX31R78ED84037 T/F7 F T/BD T/CD T/E A1 T/BE T/QL 02-APR-2008 05-DEC-2008 111556 USA 17 7M01 150102 * 18C869 * A16 42 27144
AWS Claim Key: 5927851 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08956 - * Name: MEREDITH MOTOR COMPANY, INC. Ph: 603-2794521 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:26-APR-2010 Doc #:05301001
Cust Comments: CD PLAYER WILL NOT LOAD CD
Tech Comments: C D PLAYER WILL NOT LOAD SELF TEST RADIO CONTINOUS CODES B2404 B2477 NEED TO CALIBRATE RADIO STILL NO CD ORERD AND INSTAL REPLACEMENT RADIO REPROGRAM AND RETSEST OK
1FTWX31R78ED84037 T/F7 F T/BD T/CD T/E A1 T/BE T/QL 02-APR-2008 05-DEC-2008 111556 USA 18 7M01 150102 8C3T 18C869 EC A07 42 28271
AWS Claim Key: 5850990 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 67803 - * Name: FORD COMPONENT SALES, LLC Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:10-MAY-2010 Doc #:03187010
Tech Comments: Dealer RO# 53010 1878# A0464111
1FTWX31R78ED84037 T/F7 F T/BD T/CD T/E A1 T/BE T/QL 02-APR-2008 05-DEC-2008 111556 USA 29 * * * * * * * 47662
AWS Claim Key: 7353872 Trx Code: 11B23 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08956 - * Name: MEREDITH MOTOR COMPANY, INC. Ph: 603-2794521 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2011 Doc #:05853801
Cust Comments: 11B23 PCM REPROGRAMMING
Tech Comments: REPROGRAM PCM/TCM/IC AS PER FSA INSTRUCTION
I just bought a 2010 F-350. First drive, I got 22mpg's on the highway. The great thing about diesel is that they're versatile in performance. Throw a couple of bolt-ons on the motor and plug up a programmer and you get a few easy extra MPG's.
He ended up with a different '08 F-350.
SC/LB Lariat with the 6.4. Haven't driven it yet but I rode 100 or so miles in it- nice truck. Last two diesels I spent any time in were a '95 F-350 with a bad shifter boot (lotta noise come up around that stick), and a '98 Cummins. 'Spose it goes without saying this one was a little quieter. :rofl:
Got some miles on it (130k), but he's happy with what he paid for it.
