Testing Vacuum Advnace
What is a good way to test a vacuum advance? I have heard of people saying take a screw and unplug the vacuum hose then put the screw to block it, if the truck runs the same then there is a problem....
I dunno so I thought i'd ask you guys
Pop the distributor cap off and physically look to see if the arm moves when vacuum is applied to it. Use a vacuum pump with gauge, the gauge should stay stationary and not bleed down.
