swapping rear axles
i have found a doner 78 f150 truck near my town to swap the body/running gear off my 78 f250 onto and wanted to keep the 1/2 ton springs front and rear my ? is the rear springs are 3" wide for the f250/dana 60 axle and 2.5" for the f150/9" is bolting the dana 60 onto the 2.5" springs going to be a problem with a 1/4" clearance on each side of the ubolts? i think it should work but has any one did this before and had any problems with things shifting around?
mtflat
Flatheads Forever
2,559
147
Can't you just use the bolt plates off the half-ton? If not, I'd probably head to the local junk yard and get a pair.
