supercamper bedside
camperspecial
truckjunkie
19
Austin,Tx
I have a 1973 super camper with some substantial rust on the bed side. I want to replace the bedside {drivers side} but Im unsure if the dimension are the same as a 1/2 ton long bed. I don't want to buy a new one only to find out that its not the same. any help would be helpful
Thanks
Ken
Doesn't the "Super Camper" have the rear axle further back?
Or am I thinking of something else?
No Ian, you are correct. The F350 Super Camper did have the axle further back.
A_G
wuh?
3,188
74
Tulsa, Ok
chop cut and modify cuz i highly doubt your going to find one in good shape.
Brian_B
blank
It is unlikely (unless they are hugely popular) that the aftermarket would make a new bedside for a special bed.
You can check with the aftermarket supplier in your state. Run a search for "aftermarket body panels" in google for your state.
Also, check with LMC (website). They have a lot of standard body panels.
Do you have pics of the bedside? That would help us a lot.
If you can post some...we might be able to locate someone who sells patch panels from a standard long bed you could weld in.
That could be the only option. :(
Anthony said the same thing...just differently. LOL
885
53
WB on a standard 8' box is 133", WB on yours should be a 140", they won't interchange without modification.
Lost
PA Chapter leader
3,288
central PA
The wheel well is same but further back so the lower back of it is different . As for after market drought it way to few made.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
Thanks
Ken
All 1973/76 F350 Super Camper & Trailer Specials were built on the 140" wheelbase only.
This wheelbase continued to be used thru 1979, but you cannot use the left quarter panel (bed side) from a 1977/79 without modifying it.
The 1977/79's have fuel filler doors, so the filler necks and related parts are different than the 1973/76's used.
D6TZ9927841A .. Left Quarter Panel / Fits: 1973/76 F350 w/140" wheelbase.
You want a BRAND NEW original?
greensalescompany.com located in Cincinnati OH has ONE: 800-543-4959
This is the only Ford obsolete parts dealer that has it. No Ford dealer has any.
Say Chris, if you call a used panel a "needle in a haystack" what do you call this NOS panel?
You can see the wheel well location in this pic
camperspecial
truckjunkie
19
Austin,Tx
sorry i was out of pocket for a couple of days. I'll try and get some pic of my truck and rust spots. Im new to the ford thing. I usually play with 68-72 gm trucks but my granddad had one of these so you know the rest.
BKW is that part # for a factory replacement part? If so thats awsome!
Ken
A_G
wuh?
3,188
74
Tulsa, Ok
see i have a bumpside mutt. Kinda of a special order from the factory with a bit of camperspecial thrown in there. but your best bet is to chop/cut/modify.
