Storing my truck..
TheRoadVirus
High-Steppin' Mo-Sheen
2,461
31
Ontario, Canada
I have some q's for you guys that're kicking around in my head.
I'm going to have to continue storing my truck until I'm done school and get my own place with room to work on it. Thing is, it looks like I'm going to have to store it in the (back)yard. On grass.
Is it really that much worse to store a vehicle on grass than on pavement? I've always thought that there's alot more moisture present, therefore increasing the amount of rust that comes along. Yes, no?
Anything I can put down to prevent/slow this process? gravel.. etc.?
Or should I just say screw it and spend the money I can't really afford to spend and put it into a storage unit or something?
Pros/cons? I guess..
Thanks guys.
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
Well i could see the moisture being a problem, but that area of grass will soon die out due to no sun...
how long do you think you will have it stored?
Heck pulling it out once a month or so to fiddle with it would probably be a good thing....
Truckin4life
9,037
San Antonio, Texas
Eh its only a year...
Does it run?
If so i would start it up and move it everyonce in awhile, drive it around the block or something...
Maybe once a month or so...
Let it get up to operating temps....
TheRoadVirus
2,461
31
Ontario, Canada
Oh yea, she runs. I didn't start it for over a year, put in a new battery and it fired right up. Not the greatest for it, but I forsee quite a bit of new things in it's future.
Grass, dirt gravel. dosn't matter. The moisture coming out of the ground does.
Covering a vehicle that's over the above makes it the worst thing you can do.
Building codes today requires moisture barriers between ground and living spaces for the same reason.
Concrete driveways are good. concrete driveways with moisture barrier are better.
Carports with concrte and moisture barriers are better
See where I'm going with this yet.
Garage with moisture barrier and climate control...Excelent
surewhynot
Rep whores make me sick
13,843
821
Florida
Slightly off topic, but you should add some stabil to the gas to keep it from varnishing up the fuel pumps.
Truckin4life
9,037
San Antonio, Texas
On tony's topic, is it a good idea to run the truck for awhile to get the stabil in all the lines and all or just dump and let sit kinda thing?
surewhynot
13,843
821
Florida
I would run it and let it get into the system. The fuel could varnish up injectors and everything.
89frankenford
Grabber Green Consultant
4,547
147
NH
heres an idea....drive it on top of a large tarp then fold the tarp up and over the truck and have another tarp over the truck. that way the truck is completely wrapped and would be better then having it sit on the grass directly...cheap and easy
emtzach
i get paid to do this
if you doo the tarp thing make sure you through like ten bokes worth of moth balls everywhere so the damn little critters stey the hell away from the inside of the truck
flareside_thunder
7,812
246
the tarp thing is a good idea...or you could send it to Florida...I don't know how much storage is up there but around me it's only like 35 bucks a month and you shove it in a unit with a door....
