- 106
- 0
Okay, I need to back up and start again with my overheating truck problem.
Yesterday I drove through two counties looking for a fan shroud, because two mechanics said ‘that’s your problem.’ There was no fan shroud to be found and I got home tired and disgusted with my truck literally blowing steam out the wheel wells.
(For those new to this we're talking about a '78 F150 300 4X4 without airconditioning) If you're interesting in the backstory See "Overheating" for all the back and forth that went back and forth.
Here is some more information I hadn’t mentioned before. About six years ago I stopped needing the truck for about two years and it was hardly used and, Okay, I’m ready to admit it. There was only the weakest solution of coolant in the engine, maybe almost water. One day, dead of winter, I took it out and it overheated after only a few miles. I wound up getting a new radiator, but it would still overheat now and then. Last summer I was taking it on long trips and it would overheat on the highway, or going up steep grades. I changed out the radiator again during the winter and that seemed to fix the problem. Now . . . last weekend I drove across the state (daylight, hot, highway) and it rode fine. Then I drove it back the next day. Same conditions and it overheats half way back and has been overheating every day since
Now I’m thinking there must be something clogging the system. Nothing else has changed.
For those new to this:
I have changed the thermostat (run it with no thermostat, run it with a 180 degree and a 160 degree). This does not help.
I’ve changed the radiator cap: 13 pound, 7 pound, run it with the cap loose. All no help.
I’ve replaced the water pump. This has not helped.
I’ve checked coolant mixture and levels. They are right.
The fan is turning. The gauge is right (it definitely overheats, take my word for that).
There is not water on the dipstick.
There is no white smoke coming from the exhaust, or water apparent in the exhaust.
I do not see bubbles in the radiator.
At idle the water seems to be circulating in the radiator just fine.
The truck runs good otherwise. The timing seems right.
I’ve been told “fan shroud” but it has run without one for ten years and ran two hundred miles on the highway one week ago without a problem . . . without one.
What would explain the truck running fine on the highway on Sunday and overheating on Monday with the same conditions.
Yesterday I bought some Peak brand “Super Cleaner and Flush” and think I will try this. I can’t think of anything else to do.
Anybody have any other ideas.
