steering shaft repair 78 f150 ?????
X36
41
3
I believe the steering shaft is binding at the rag joint.(feels when I'm steering that theres a flat spot.My steer wheel doesn't turn through smoothly.I was wondering is it possible to soak/lubricate it.To see if it will come out of it.Or is it a lost cause.Just "end the pain" and replace it.Thanks
TexasNomad
FTFS Designated DRINKER!
If your rag joint is bad then replace it ASAP!
If you have tilt steering then it will cost about 10 bucks to fix, if you DON'T have tilt steering its going to cost around 70+ bucks..
Yea for sure, DO NOT drive it untill you get that steering fixed!
bucks77ford
We will Rise Again
2,409
101
Kasson, Minnesota
