- 2
- 0
I am having some issues; yesterday my '02 F350 battery was dead, I could jump start it and it would start right up and stay running on it's own power. I decided to disconnect the battery and get a new one so it had no battery connected for about an hour. After installing the new battery it will turn over well but it won't start. I have tried the obvious things like checking all fuses and relays which were all good. I disconnected the intake pipe and sprayed carb cleaner in there and it will start just long enough to burn that off. I refuse to believe that there is a huge coincidence that when I replaced the battery my fuel pump went out, but I don't hear the fuel pump when putting the ignition in accessory. It has the 5.4 liter engine. The key does not have a chip inside of it so I don't think its a problem with the engine immobilizer, but at this point I'm at a loss for ideas.
