- 2
- 0
Hello to all - new to the forum...
My "new" truck is a 1986 F350 with 460 and 4-spd manual.
Trying to figure out a starter problem. Starter had become hard to start - would sometimes start after tapping with hammer. Replaced the starter today. Got nothing when I tried it and nothing when I tried to attach jumper cables to it outside the vehicle. Tried that with its own battery and with another vehicle while it was actually running. Figured I got a bad starter, so I took it back. But... It ran out and rotated just fine for them!
So, trying to track down the problem, I tried bypassing the solenoid on the fender. I removed the heavy gauge wire from the solenoid and touched it straight to the hot post on the battery. It was obviously taking power (welded to the post), but no starter movement. I took the cable off at the starter as well and cleaned both ends (nice and shinny). I checked the cable and it showed zero ohms resistance (though, I guess that would show me if it ALSO had a short). Put it back - same results.
Replace the cable now?
