Split hub picture
bucks77ford
We will Rise Again
2,409
101
Kasson, Minnesota
That would have scared the hell out of me. I've never seen that before. Hope you get er back together OK.
I got parts coming in next week. I was worried about the condition of the spindle, but it looks ok. I do need to buy new lockouts though. The old one kinda came apart when the wheel bearing came apart.
1985 Ford F-150
Country Boys Can Survive
7,816
307
Tooele, Utah
Yep thats what happened to mine. If ya got the money id get the Warn premium hubs. I got a set on my 85 and they havent given me a lick of trouble. Same with the ones that were on the 76.
1985 Ford F-150
7,816
307
Tooele, Utah
I dont know. I never really paid attention to see what they were made of. They are all metal though and very simple to work on and rebuild. Ill go out and look at the 85 and see.
blackhat620
You Had to be There
1,687
150
Arizona
Dan, are the premiums really made out of brass, or are they brass-coated? Thanks for the info.
No brass in the Warn hubs, the brass colored dial has been coated this color. The Premium hubs are all metal and the dial is Zinc - Aluminum Alloy ("ZA Alloy"). The clutch ring and inner drive gear are 4140 steel.
www.warn.com/truck/hubs/premium_hubs.shtml
www.warn.com/truck/hubs/standard_hubs.shtml
http://en.wikipedia.org/wiki/Zinc_aluminium
Here is the Warn application chart, read the notes at the bottom of the chart to make sure you get all the correct parts (ie "spindle nut kit if needed"). www.warn.com/truck/hubs/premium_application_chart.shtml
Got my parts in yesterday from JBG. The hub already had the bearing races installed. When I looked down inside the hub, I could see the dreaded "Made in China" stamp on the race. Those were tapped out and I installed the races that came with the timken bearings. Also put in a new needle bearing on the spindle - took about three hours of "tapping" to get that one out.
I also noticed that the new raybestos hub did not have the slots for the lug nuts, but the lug nuts had the serrations. It took a while to get those in also.
So, new hub, new bearings, new lockouts(Warn premium). I had replaced the brakes and rotors a couple of months ago, so now all I need is a test drive.
LIFE IS GOOD! Thanks everybody for the help and suggestions.
Glad you got everything back together.
