Spark plugs for 330FT
Looks to be the typical plug gap for points, .030 to .035, you canuse for the most part whatever plugs you want that fit properly.
Ok, did a little searching, and got a little more for you, it is all the original Motorcraft parts from a user by the name of Numberdummy, liberated from another site.
C3TZ-12405-A .. Spark Plug (Motorcraft BTF-31)
18mm / 13/16" hex tapered seal / .028 - .032 gap setting
Fits: All 1964/72 330/361/391 engines.
For future reference, here's the rest of the tune up parts.
B8Q-12171-A .. Point Set (Motorcraft DP-12)
B7A-12200-A .. Rotor (Motorcraft DR-5)
C9AZ-12300-A .. Condenser (Motorcraft DC-13A)
B7AZ-12106-A .. Distributor Cap (Motorcraft DH-146)
D2PZ-12151-A .. Breaker Plate (Motorcraft DB-187-B) This is a one piece plate, it replaced the original two piece plate.
C5AZ-12192-F .. Primary Spring (Motorcraft MS-472)
C5AZ-12192-A .. Secondary Spring (Motorcraft MS-467)
C5AZ-12210-B .. Distributor Cam (Motorcraft DF-343)
C1VF-12216-A .. Primary Wire (Motorcraft DW-12)
C5AZ-12370-A .. Vacuum Advance (Motorcraft DD-190)
D4PZ-12259-TR .. Spark Plug Wire Set (Motorcraft WR-3820-CR)
