Spark plug Cleaner
Newbie question alert!!!!!!!!!! Alright fellas, the #1 plug on the dside and the #3 plug on the pside get oiled up pretty good every 2-3000 miles or so, and I wanna clean them. Last time I just replaced them because it was that time. Anyway, I've never had to clean spark plugs before between changings, so what do I need to do/use on the oiled up plugs? Just wipe them clean with a rag...is there a fluid I should let them sit in...or just go buy a couple new plugs when they get too goobered up? Thanks for any input.
CowboyBilly9Mile
442
USA
I'd put a new one in rather than try cleaning them, You might consider going one heat range hotter on the ones that are getting oily.
*Beware of spark plug sandblasters as it can be difficult removing all of the sand from the plug prior to reinstalling in the engine.
Alright...I figured it would probably be easier just replacing the plugs, besides for the $6 it would cost me to get new ones...I figured it would be worth it. I swear, with the money I've put into trying to cover up the oil problems, I coulda bought a sweeeeeeet replacement engine already...haha.
LACQUER THINNER and a small paint brush
mrxlh
Oilfield Trash
5,904
430
Stigler, OK
Good electro clean works well.
Ridgerunner
573
Stillwater Ok
Ben I have used Mean Green in a tin coffee can and got them spotless by letting them soak then rinsing with lots of water and regap
