slow fuel fill
TSB
07-23-13 SLOW FUEL FILL
Publication Date: November 12, 2007
FORD: 2005-2008 F-250, F-350
This article supersedes TSB 07-15-4 to update the Part List.
ISSUE:
Some 2005-2008 F-Super Duty 250/350 vehicles equipped with a 5.4L 3V or 6.8L 3V engine may experience premature automatic shut off of the fuel fill nozzle, or repeated fuel shut off at the fuel station delivery nozzle. Vehicles operated in muddy or dusty environments can encounter a dirt-clogged carbon canister system. More specifically, the carbon canister's vent, fresh-air box and filters become clogged with dirt from operating in such environments.
ACTION:
Use the following Service Procedure to resolve the concern if the carbon canister system is dirt clogged.
NOTE: THIS TSB ONLY APPLIES TO F-250/350 PICKUPS, AND F-250/350 PICKUP BOX DELETE/CHASSIS CAB VEHICLES
SERVICE PROCEDURE
Inspect the vehicle canister system and if it found to be dirt clogged then continue with this TSB.
NOTE: IF THE VEHICLE'S CANISTER SYSTEM IS NOT DIRT CLOGGED, THEN PROCEED WITH NORMAL DIAGNOSTICS AND DO NOT CONTINUE WITH THIS TSB.
Vehicles with Pickup Boxes:
Replace the carbon canister assembly with a canister built after 10/1/2006. This canister has a revised internal filter media, and went into production on 10/1/2006. The date code is on a black sticker located on the carbon canister assembly.
Relocate the fresh-air intake port to a more protected location using the fresh air hose kit, for pickup applications only.
Replace fuel cap assembly if the vehicle was built before 5/16/2007.
Vehicles with Pickup Box Removed or Chassis Cab:
Relocate the fresh-air intake port to a more protected location using QVM bulletin Q-132 at the body builder's website - https://www.fleet.ford.com/truckbbas/index.htm for fresh air intake routing recommendations.
PART NUMBER PART NAME
7C3Z-9049-A Fresh Air Kit - (MY 2005-2007)
8C3Z-9049-A Fresh Air Kit - (MY 2008)
6C3Z-9D653-F Carbon Canister - Pick Up (MY 2005-2007)
7C3Z-9D653-E Carbon Canister - Chassis Cab
8C3Z-9030-A Fuel Cap Assembly
7C3Z-9D653-A Carbon Canister - Pick Up (MY 2008 w/Midship Tank)
