Sloopy Steering
Mr. Stroker
CASE IH
3,121
67
Michigan
Hey, my steering seams to be getting more sloppy.... So i was thinking its my box. But first i want to know if there is a rag joint between the steering shaft and the box?
{Note}. I have a Whole new tie rod kit that i bought when i first got the truck. So those are all brand new.
Any ideas?
Have someone turn the wheel while you look at the steering, then you will be able to see whats moving on ya, its either play in the box, or them tie rods are gone again. There is no rag joint, there all mini u joints.
Mr. Stroker
CASE IH
3,121
67
Michigan
Ok kool. Yea i had my cousin turn the wheel back and fourth and i definatly think its my box. Il have to check and see how much a reman box is. Thanks for the help
surewhynot
Rep whores make me sick
13,843
821
Florida
When looking at reman boxes, find out who does the remanufacturing of them. Then google them. Some suppliers are better than others.
Gunner
57
Billings
Sloopy steering?
There's only one thing you can do man..............
"HAAAANG ON SLOOPY! SLOOPY HANG ON!"
Thats about all you can do ;)
Gunner
Sloopy steering?
Gunner
Hahahha nice catch. I didn't see that the first time around.
Keep us posted on the reman box Mike, mine's pretty 'sloopy' too :rofl:
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
You can take up the movement in the box usually by turning the adjusting screw on the top of the box. I'll check to see if theres a procedure for it.
Mr. Stroker
CASE IH
3,121
67
Michigan
Gunner that is the truth. It seams like the more i try to correct it the sloppier or the more it goes all over the raod. If i keep just one hand at about 9 o clock and just correct lightley il go down the road straight. But thats a PITA! d-kuzmen im at school and il check out alldata while im here. Thanks
32
2
hey jr
if they faised out the rag joint in the 80s then why does my 92 have one at the top of the box ,its under that little black plastic round thing that covers it
hey tony im still awaiting delivery on the silverbullit so i can make grabber green babys with it.
biggin
Mr. Stroker
CASE IH
3,121
67
Michigan
then somethings up with it lol. Mine is bolted rite to the box and no rag joint at all..
Lost
PA Chapter leader
3,288
central PA
My 93 has none. But who knows .
Wierd. Yea you losen the nut on top of the box that holds the adjuster from moving. Dont go 2 tight with it. 1/4 turn at a time and try it out.
Mr. Stroker
CASE IH
3,121
67
Michigan
Ok yea il try it. Thanks all
Mr. Stroker
CASE IH
3,121
67
Michigan
Ok i tried it.... Yea that thing aint gonna turn.... I would say someone messed with it before but i had to use a breaker bar and an added bar to get that dang thing loose! So idk. Im gonna call around tomorrow to see how much a steering box is.
I heard napa got them for like 170 or so.
Mr. Stroker
CASE IH
3,121
67
Michigan
Ok good deal. Imma go shop around tomorrow. How much do power steering pumps run? Ive got a bit of whining coming from mine.
