shocks and blocks question..
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
most of you know.. im installing F350 springs they arrived btw just got to go pick them up.. now for the rear lift blocks.. should i get a 4inch block or a 3 block ? to replace the stock 2" block now??
to match the higher lift F350 spring ??
and the shocks
is the one from the rear longer that the front? i guess so.. nway i was thinking of ordering these for the front
FRONT
http://store.summitracing.com/partdetail.asp?part=SJA-N8023
REAR
http://store.summitracing.com/partdetail.asp?part=SJA-N8060
the lengths seem to matches.. i measure them from the shocks i have now on the truck..
chris F350 helped me allot thanks budd.. :wavey:
Just get like the lift shocks for ur 250 now that your going to stay with ur axle. So like ebay shocks for whatever lift your gettin. Id go with the 4" blocks caus that will give you the nice raked look that my truck has. You can also put it all together then measure for shocks. Granted you wouldnt be able to drive. Or just get stock F350 shocks from your parts store.
Here is the 4'' Ford blocks.
Ed
Anybody know what the point of that wing is that sticks off the side of the stock blocks? I've always wondered...
I got to look at my truck. I dont think the bumpstop is there.
andym
Real men are fanatics
604
Roseville, CA
It should be. Those are the bumpstops for the rear suspension.
F 150Cobra
3,642
104
Aruba
yeah they are.. the rubber is on the chassis and there is the bumpstop itson my stock F250 block also.. soo Ed do you sell those??
how much ? does it come with U bolts?
YES I DO!
the most popular one is F81Z5598DA x2 (pictured)
list $49.98ea sell $35.98ea ubolts are separate.
There is a couple of differences on some models so if you order send vin and I can double check and make sure you get the right set up.
Ed
