run-on starter
80
Hi, I'm new to this forum. I have a '87 250 with approx. 100k miles on the clock. You guys were recommended for your expertise. How about this problem... Twice now when the ignition has been turned off the starter begins to spin. Doesn't want to engage, just spins. Wev'e had to cycle through off/on about 6-7 times before the starter ceases to spin when ign. turned off. I searched the archive last night and didn't get anywhere. Have any of you had this problem?
TexasNomad
FTFS Designated DRINKER!
That sounds to me like your Ign switch is going out it may have a bunch of junk built up in there and could be jumping that would be the easiest and cheapest place to start.
It could also be a relay or a wire that's been rubbed bare I really don't believe it could be the starter, have you checked all the wires leading from the starting all the way in to the firewall..
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
Welcome, your starter solinoid mabe sticking, also check the ignition switch and also the rod in the steering colum mabe sticking holding the ignition switch to the start position.
Do you have a remote starter switch or a jumper wire?
Try running it from the solenoid on the fender so you know that power to the starter is being released thru the solenoid.
Sounds like bad starter relay/solenoid to me
