Rough Starting / Rough Idle at warm
I have a 2007 F350 Diesel with about 53,000 miles....lately when starting she is real rough at idle. Almost like its not firing on all cylinders. After letting the truck warm up for a long while it runs OK.....shifts hard for a little longer...but runs on.
common?
troubles ahead?
Thanks
common?
troubles ahead?
Thanks
How is it at cold start? Is it more of a problem cold or warm? Or does it not make a difference? Any smoke? If so, color/smell is important. Any check engine light? Have you had battery/charging system issues recently?
Cold start its ROUGH.
More of a problem COLD..once it warms up runs good
no lights on dash at all
no battery / charging system problems.
Theres a reflash that repairs the injector stiction issue (cold start). If its updated fully, more diagnosis is needed. Where are you at?
Mine is doing the exact same thing. blacksnapon can you help me?
1FTNW21P13ED43547 I did just recently have to change the alternator again, it was overcharging.
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTNW21P13ED43547 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-MAY-2003 17-JUL-2003 121728 USA 1 6L17 011202 2C3Z 25519A70 AAC B95 33 35286
AWS Claim Key: 2218734 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01159 - * Name: ACTION FORD-MERCURY, INC. Ph: 843-3835121 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-2003 Doc #:02034901
Cust Comments: CUSTOMER STATES OVER HEAD CONSOLE COMPARTMENT BROKEN.
Tech Comments: OVERHEAD CONSOLE TRIM DOOR LOOSE POOR FIT REPLACE TRIM ASY ON OVER HEAD CONSOLE
1FTNW21P13ED43547 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-MAY-2003 17-JUL-2003 121728 USA 1 7L01 130601 XC3Z 13832 AA A34 42 35286
AWS Claim Key: 2218733 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01159 - * Name: ACTION FORD-MERCURY, INC. Ph: 843-3835121 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-2003 Doc #:02034902
Cust Comments: CUSTOMER STATES HORNS NOT WORKING.
Tech Comments: CHECKED FOUND HORNS ASY INOP RUN DIAG TEST AND REPLACE HORNS ASY RETEST
1FTNW21P13ED43547 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-MAY-2003 17-JUL-2003 121728 USA 4 2I04 NANANA YC3Z 12B533 AA D02 42 4293
AWS Claim Key: 3180451 Trx Code: 2 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 01159 - * Name: ACTION FORD-MERCURY, INC. Ph: 843-3835121 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-2003 Doc #:02131801
Cust Comments: STALLS OUT AND HARD TO START COLD
Tech Comments: RUN DIAG TEST ON GLOW PLUG SYSTEM FOUND CONTROL ASY FOR PLUGS REPLACE CONTROL ASY AND RESET
1FTNW21P13ED43547 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 30-MAY-2003 17-JUL-2003 121728 USA 34 * * * * * * * 41613
AWS Claim Key: 13639020 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01159 - * Name: ACTION FORD-MERCURY, INC. Ph: 843-3835121 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2006 Doc #:03210203
Cust Comments: ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE AFTER RECALLS DONE
Tech Comments: ROAD TEST AFTER RECALL DONE RECALL 59B01 MILES OUT AND MILES IN AFTER ROAD TEST
AWS Claim Key: 13639021 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01159 - * Name: ACTION FORD-MERCURY, INC. Ph: 843-3835121 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2006 Doc #:03210202
Cust Comments: CERTAIN 2003 2004 YEAR F 250,350 450 AND EXCURSION VEHICLES CONTROL MODULE RECALIBRATION .
Tech Comments: ON SOME AFFECTED VEHICLES THE EP SENSOR MAY CAUSE CONDITIONS TO SET THE CHECK ENGINE LIGHT . RECALIBRATE CONTROL MODULES AND ROAD TEST
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
I would recomend checking to see if there are any codes present when the trucks are cold, if you have a p0611 or all 8 injector codes the ficm may be faulty or in need of a reflash. If you know anyone with a scan tool that will show pid data you can watch the FICM_M power to see if it drops below 45volts when the truck is cold key on engine off. Low Ficm_M power will cause the truck to start hard and run rough untill it warms up.
