rough idle ,black smoke ,and blowby
Lost
PA Chapter leader
3,288
central PA
Looking into this for friend.
he has 87 down F350 cab n chassie with 460. Carb was rebuilt . The truck idles rough ,blows black smoke and is pushing dip stick out some.
New plugs wires ETC. he did Compression test 115-125 LBS. (Closer than last crate engine I got) .
Now till the compression test I thought the ring may be bad .
Enlighten me guys. Worn rings allowing blow by when hot? Gasket issue?
Thanks ahead of time.
surewhynot
Rep whores make me sick
13,843
821
Florida
Maybe a head gasket blowing compression into an oil passage?
Lost
PA Chapter leader
3,288
central PA
I wondered that .Just got email 1/2 hour ago . Get up to see this weekend.
squirt some oil into the spark plug hole, then check compression. If theres a big difference, bad rings/piston. You can use the air adapter for replacing valve seals....apply air.....listen for where the air is coming out (tailpipe/oil cap/intake)
Lost
PA Chapter leader
3,288
central PA
Is the PCV hooked up properly as well as the breather cap on the other valve cover?
also, if the carb was rebuilt, who is to say it was done 'right'?
yea i dont have luck with rebuilds . But never had push out dip stick .
Lost
PA Chapter leader
3,288
central PA
You one smart cookie . I'll tell him.
flareside_thunder
7,812
246
Did he play with the mixture screws on the carb to try and lean it out?Sorry just thinkin this out from first to last......I've never seen a rebuilt carb that was exactly in tune when you got it back.....
