I've been thinking about putting bigger tires on my Bronco and I want to keep the speedometer accurate, has anybody ever changer one? What is involved and is there a write up you could point me to?
If you aren't going alot bigger, I wouldnt worry with it... some aren't even close from the factory. Given, our Lumina is a Chevy... but it is off by about 4mph. according to our GPS.
Aslong as it's within 5ish, you shouldnt have to worry... just run the speedlimit.
Speedometers are always off, and technically GPS is off, very slightly. It came with 235s stock and it has 255s on it currently so I don't know if it was changed out when the tire sized was increased.
Taylor, I'm not entirely sure yours has a gear. In 1988 I'd have to look in my book but I think your speed sensor is on the side of the transmission and it is electronic.... Maybe not for AOD.
Oh, if I were going to change tire size it would be 32".
Since the truck came with 235's that's going to be a rather large step up in tire size and both the speedo and odometer will be way off which means your milage is going to appear to go down quite a bit. Changing the speedo drive gear is simple you just have to choose the right gear, but you're also going to find those tires make the truck pretty doggy, a gear change to 4.10's would put everything back to the stock overall drive ratio and elminate the need for a speedo recalibration.
