Does anyone know if the speed sensor can do this although the cruise control still works?
I wish I had a diagnostic computer..
This is on the '90 dually.
Any symptoms?
Pulling codes will poinpoint which sensor is causing the issue.
I think your speed sensor is on the transmission and it's gear driven.
You don't need a scanner to pull codes either and it's easy to do....hell if I can do it than a chimp can. http://www.fordfuelinjection.com/?p=13
