Question About Gas Tank Sending Units
I have a 1978 F-150 4WD, 133" WB with the original plastic, midship 26 gallon tank. I replaced the sending unit on the tank about 9 years ago, but the sending unit and/or the float appears to have gone bad.(No level indication on the gauge)
I want to order a replacement sending unit, but it seems there are two lengths to choose from - a 6" sending unit and a 10" sending unit. I could pull the old sending unit and measure, but I would rather order a replacement and replace the sending unit all at the same time.
Can anyone provide some insight as to which unit goes with the tank that I have?
3,291
188
In my own world
How deep is the tank?
There are 2 different tanks, one hangs lower than the other. I think the plastic tank is deeper, than the steel tank
I don't remember, but after looking at the depth of the replacement steel tanks(aftermarket), It looks like the plastic is quite a bit deeper than the metal. I'm thinking 10" is for the plastic. Thank you.
3,291
188
In my own world
No problem
37
I just had mine out of the plastic tank last summer when I was revamping my fuel system, but I can't remember how long it was. It looked good and was working with the gauge so I didn't pay that much attention to it. Just had to replace the rear one with the new tank. Now the front one isn't working! I think it has more to do with the plug not making good connection though.
Keep us updated with which one works.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
I have a 1978 F-150 4WD, 133" WB with the original plastic, midship 26 gallon tank. I replaced the sending unit on the tank about 9 years ago, but the sending unit and/or the float appears to have gone bad (No level indication on the gauge).
The float is available by itself and is made of two pieces of brass soldered together. Solder breaks down, gas seeps in, float settles towards the bottom of the tank.
The float (C0AF-9202-B) is available from Ford and all the repro parts sellers.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
Thank you, Bill. This is a 49 state truck, non evap emissions with a 26 gal tank.
Doesn't matter, the float is the same: 1957/79 all Passenger Cars & F100/350, 1961/79 Econoline & 1966/79 Bronco.
