Question About Charging Voltage On Not Ford
I've been getting some spurious CEL's and other alarms on a Not-Ford, and have been reading that a low-voltage situation will cause some unusual alarms to show up. I have a brand new battery, and the alternator is original(127,000 miles). I'm wondering if the alternator is hit or miss.
I'm getting 14.0 volts at the battery when the engine is running at 1000 rpm. Is this an acceptable voltage produced from the alternator?
On edit, the battery voltage with the engine off is 12.5 volts.
SuperCab
547
Montana
To the best of my knowledge the minimum charging voltage for a 12v lead acid battery is 13.8 volts. Sounds like your alternator is fine in my unprofessional opinion
smokey
Hitech hillbilly
14ish is normal output. 12-13 is normal battery voltage. I know the wife 2017 wrangler threw a light from sitting all winter and the battery was low.
3,291
188
In my own world
Battery volts and charge are fine.
Time to hook up a scanner and pull the codes.
post them, we will help figure out what's going on
3,291
188
In my own world
CowboyBilly9Mile
442
USA
Normal. What are you working on? This because, I have an ELM327 adapter that's looking for a good home, the price is so right, and this + one of several available apps will allow you to pull the generic OBDII codes on your Android phone (tablet).
Thank you all. I have an OBD II scanner that came up with only one code which indicates a small evaporative emission leak (P0456). I'm thinking maybe gas cap, so I ordered a new one.
I might get banned, but the car is a 2009 Toyota 4runner with 4.0 liter engine. I am getting the check engine light, and also the "VSC Off"(Variable Skid Control) light at the same time. Some reading has indicated that the Toyotas will throw some unrelated codes that don't apply to the real problem.
I can clear the code via the OBD scanner and it will come back in a couple days later.
Thank yous guys for your help.
3,291
188
In my own world
You have a speed sensor going south
Have fun figuring out which one
Ford's tell you which one
Yota's...... not
3,291
188
In my own world
Where were you last week when I had to buy one??????:rotz:
oh well.
'smiliedoh'
Installing a new gas cap cleared the check engine light and the "VSC Off" alarm. The two are completely unrelated but I have been reading that the car will cause alarm lights to come on that have nothing to do with the real issue. After about 1500 miles with a new gas cap, the codes haven't returned.
