- Moderator
- #1
OK, I've got saturday service, I'm going to pull the cab on an 08. Anything you guys want to see? I'll bring my camera.
Thats the one with a high pitched squeal under high boost/heavy load. The leaking exhaust component is on the rear of the engine. A lot less skinned knuckles doing it that way.Yes, that will be great!! What is the problem that you have to pull the cab?
Will this work?Sure...that would be interesting to see.
If you have time, write up what you actually have to unbolt/remove to get it off.
Do you think my 56 cab will come off the same way?![]()
Will this work?
Install new body bolts.
Will this work?
Special Tool(s) Universal Cab Hold-Down Strap
138-04411 or equivalent
Disconnect Tool, Transmission Cooler Line
307-441
Removal and Installation
Crew Cab Shown
Item Part Number Description
1 W712878 Front end sheet metal body mount bolts (2 required) (all vehicles)
2 W712878 Body mount no. 1 bolts (2 required) (all vehicles)
3 W712879 Body mount no. 2 bolts (2 required) ( Crew Cab only)
4 W712878 Body mount no. 3 bolts (2 required) (all vehicles)
All vehicles
NOTE: A 2-post hoist must be used to lift the body from the chassis.
With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02.
Drain the engine coolant. For additional information, refer to Section 303-03.
Disconnect the battery cables from the left and right batteries. For additional information, refer to Section 414-01.
Separate the leads from the left positive battery cable.
Separate the leads from the right positive battery cable.
Separate the leads from the right negative battery cable.
Remove the left and right batteries.
Remove the 2 hoses from the degas bottle.
Manual transmission
Lift upward on the gear shift boot to access the gear shift bolt.
Remove the gear shift bolt.
To install, tighten to 30 Nm (22 lb-ft).
Four Wheel Drive (4WD) vehicles
Disconnect the check valve from the vacuum hose on the degas bottle.
All vehicles
Remove the retaining clip and disconnect the upper radiator hose from the radiator.
Remove the bolts and position the left battery tray aside.
To install, tighten to 16 Nm (12 lb-ft).
Remove the retaining clip and disconnect the fill hose from the degas bottle and remove the degas bottle.
Four wheel drive (4WD) vehicles
Unclip the vacuum hose from the degas bottle fill hose.
Unclip the vacuum hose from the brake Hydro-Boost® hose and position aside.
All vehicles
Disconnect the mass air flow (MAF) sensor connector and unclip from the air cleaner housing.
Disconnect the air filter restriction indicator connector from the air filter restriction indicator.
Loosen the clamp on the air cleaner pipe.
NOTE: The air cleaner housing must be removed to access the A/C fitting. Install the air cleaner housing after the A/C system has been charged.
Remove the air cleaner housing.
Remove the 3 wiring harnesses from the top of the right battery tray.
Remove the vacuum line and A/C line from the right battery tray.
All vehicles
Remove the A/C line from the right battery tray.
Remove the 2 bolts and the air cleaner bracket.
Remove the battery cable from the retainer on the side of the right battery tray.
Remove the bolts from the right battery tray.
Remove the right battery tray for access to the washer fluid bottle.
Disconnect the washer fluid bottle electrical connector.
Disconnect the washer fluid bottle hose.
NOTE: The connector must be removed to access the A/C fitting. Install the connector after the A/C system has been charged.
Disconnect the electrical connector and clip from the PCM.
Disconnect the engine wiring harness located below the PCM.
Recover the refrigerant. For additional information, refer to Section 412-00.
Remove the banjo fittings and the sealing washers from the fuel cooler.
Discard the sealing washers.
To install, tighten the banjo fittings and the new sealing washers to 25 Nm (18 lb-ft).
Remove the 3 turbo charger actuator cooler front housing bolts.
To install, tighten to 13 Nm (10 lb-ft).
Remove the 2 fuel cooler mounting bolts.
Remove the studs for the fuel cooler.
To install, tighten to 38 Nm (28 lb-ft).
Remove the retaining nuts for the fuel cooler.
To install, tighten to 19 Nm (14 lb-ft).
Remove the 3 bolts (2 shown) from the fuel cooler and coolant expansion tank. Position the fuel cooler and expansion tank aside.
To install, tighten to 9 Nm (80 lb-in).
Using a suitable suction device, drain the power steering fluid reservoir.
Disconnect the hose from the power steering auxiliary cooler line and remove the retaining clip.
Unclip the fuel cooler line from the side of the power steering fluid reservoir.
Disconnect the 3 hoses from the power steering fluid reservoir.
Remove the 2 bolts from the top of the power steering fluid reservoir and remove the reservoir.
Disconnect the turbo charger-to-charger air pipe (left side).
Disconnect the cooler-to-engine charger air cooler pipe (right side).
Disconnect the radiator hose from the top of the upper shroud and position aside.
Disconnect the electrical connector from the four wheel drive (4WD) vacuum switch.
Disconnect the 4WD vacuum hose and position aside.
All vehicles
Remove the 2 upper bolts (1 each side) from the radiator shroud.
To install, tighten to 6 Nm (53 lb-in).
Remove the 2 lower bolts (1 each side) from the upper radiator shroud and remove the shroud.
Disconnect the heater hose from the left side of the engine.
Disconnect the heater hose from the right side of the engine.
Remove the nut and disconnect the compressor manifold tube assembly from the accumulator.
To install, tighten to 8 Nm (71 lb-in).
Remove the nut and disconnect the compressor manifold tube assembly from the condenser.
Disconnect the electrical connector from the right side of the engine.
Remove the bolt and the ground wire from the right fender.
To install, tighten to 12 Nm (9 lb-ft).
Remove the bolt and the left upper ground wire from the right front of dash.
Remove the wiring harness from the retaining clip and position aside.
Remove the 3 electrical connectors from the bracket on the left side of the engine compartment and disconnect the electrical connectors.
Disconnect the fog lamp electrical connector from the front of the radiator support and position aside, if equipped.
NOTE: Make sure the vehicle wheels are straight.
Place the vehicle in PARK and remove the key.
CAUTION: Do not allow the steering column shaft to rotate while the intermediate shaft is disconnected or damage to the clockspring can result. If there is evidence that the shaft has rotated, the clockspring must be removed and recentered. For additional information, refer to Section 501-20B.
Remove the intermediate steering shaft bolt and separate the shafts. Discard the bolt.
To install, tighten to 40 Nm (30 lb-ft).
Disconnect the 3 electrical connectors from the brake master cylinder.
Remove the 2 nuts and the brake master cylinder from the Hydro-Boost® and position aside.
Remove the hydraulic brake lines from the retainer.
NOTE: New O-rings must be installed before the brake Hydro-Boost® lines are installed.
Remove the 2 hoses and O-rings from the brake Hydro-Boost®.
To install, tighten to 27 Nm (20 lb-ft).
Remove the bolt from the hood release assembly and position aside.
Raise the vehicle.
Automatic transmission.......................![]()
post too long..had to edit some
The first time of any operation takes longer. This will be my first 08. The 6.0s averaged 3 to 5 hours depending on accessories (wrecker body, boom truck, etc)
