power steering prob
odogf150
YOUNG GUN
398
utah
ei i got a problem with my power steering. today i as cleaning up my front end and tightening up my stabalizer then to check it out i maxed it out and locked ther steering whell and it started leaking a bit, but when i do my daily driving my pitman arm and bolt is always wet and loose. ? too big of tires? what would be a good remedy.? and whats the problem? anyone?
Leaks aren't normal. Clean everything up and see if you can trace it to the source. Could be something as simple as a loose clamp...might be a cracked hose...might be coming down from pump and you have a crack in it. You could also put a dye in your fluid let it run through put a black light up to it and make tracing it a little easier.
The dye is a good idea to find leaks.
crzybil87
C.R.A.Z.Y.B.I.L.L
Your pump could be gettin tired and just leakina bit from throwing the tires around
