Riotnrrd
Tennessee Chapter member
On to the next problem!
I have a small leak in my 79 4x4 power steering (Ford type steering box). It APPEARS that the leak is coming from the pressure hose where it enters the steering box (I cleaned it up then started it, and the drips appear to be coming from this hose fitting). I removed the hose and took a look at it, the flare end has no obvious wear or dents. The brass fitting that holds it down also appears to be in good shape. I tightened it down to about 35 ft lbs and it still seems to be leaking. I'd estimate a drip every 4-5 seconds.
What confuses me is this: my factory manual shows a 'brass connector' or 'tube seat' which sits inside the steering box.
Question 1: Is there supposed to be an oring between the hose flare and this tube seat? Cause there's not one in there now! I didn't find one in the return line, either, cause I looked.
I'm kinda hoping its just, you know, the hose, or that I'm missing an oring. Next, I'm hoping I can replace this 'tube seat' without pulling the whole dang steering box (and how the heck would I do this?!). Otherwise I'll be looking at a rebuild ... :/
Replacement Edelmann pressure hose is about 20$
