- Moderator
- #81
I'm a fan of the 3 lb drilling hammer for most purposes- it's designed to be swung all day, and has, IMO, much better balance and feel than any of the larger hand sledges.
The pickle fork is to separate the ball joint from the spindle, Chris. It's got a taper that is snugged down tight and then hasn't moved in years. You can try just beating it out if you use the nut to protect the end, but if it's really stuck that'll still be a problem. The pickle fork acts as a wedge and pops it apart much easier.
