Pics of my 557 in my F-100
I think I'm ok with the short air cleaner. With my 472 I had o vacuum at wide open throttle through 6000 rpm. With this motor I'm to busy trying to keep it on the road to look at the gauge. Maybe after I put on my drag radials I'll be able to check.But until I get a load of mulch,the 32x12.5 reguls stay on. Randy.
ford141
got torque?
SHooOrrt! bed!!!
Woot!
can I barrow it for the weekend?? :D
Settle down Nomad, it's a long bed, so you don't want it...
Give it to me instead :jumping:
Can't wait to see the drag strip results, please get some video! I'll be building a stroker for my '79 in a few years as well.
Blade
Backwoods boy
4,657
225
In the boonies
im speachless! Great good man, great lookin truck!
Torque Oplenty. You can get by with pump gas with aluminum heads,but that is about the limit. I have ran pump gas in a 466 with iron heads and about 10/1 compression by retarding the timing, but that cost horsepower.
bucks77ford
We will Rise Again
2,409
101
Kasson, Minnesota
I should be able to run pump gas on my 521 with aluminum trickflows and a 10.5:1 compression. Right now I have an E85 carb to be able to run a higher Octane pump fuel since it is readily available in my area.
Ridgerunner
573
Stillwater Ok
What heads did you get?
