ordered my sound deadener
i gotta admit i just did up to the fire wall coudnt see ripping out all the hard ware to get in there but may do on the sc as i stripped every thing from the dash leaving only the 2 bolts and the top screws for my body man to remove for painting on that one im half way there any ways the doors are a little harder to do working through the access hole as i did the outer panel also i did see a fellow at a car show once that installed it on the out side of the fire wall and then used spray on under coating over it didnt look too bad if you like black
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
It can be done like that...
I usually put it up to the firewall, then i cover what ever else i can...
I will remove SOME stuff but usually not everything comes out...
When i do the 250 though, thats likely how it will happen.
that would seem a lot easier doing that from the outside just ask any one whos had to change any thing under the dash heater core with air cond is a good one i usualy just pull my seat now a lot better laying on "solid" floor than half in half out at my age it realy starts to hurt after a while lol
