- Moderator
- #1
Does seeing a cab pulled, turn you off from a particular model/engine, or does it make no difference?
Just remember,Todd, by pulling the cab on a 6.0, I can have an engine out, and replacement back in and running, in 14 hours. How long did your buddy take?It's always a turn on to see an engine, but it does make me not want a 6.4L that much more. What a cluster muck!! I thought the 6.0L seemed complicated looking at first, but that thing looks like a jigsaw puzzle, and I'm not that good at them!!
Remember, this all started because "certain techs" discovered that even without Fords blessings, if you pulled the cab on the 6.0, instead of 24 hours, many jobs can be done in half the time. Ford saw that this was a viable way to do things, and changed their own minds. Besides, how much "basic" stuff is left, that you can do?turn off... Doing basic stuff short of a rebuild should be an attainable goal without pulling the entire cab.
The process is cool, but it's not cool to necessitate that kind of extravagance.
Nah, In fact, if you look at one of the pics, you can see the service manager on the other side taking his own.Turns me ON if anything. It's awesome that it can be done so easily and on that truck makes the engine look really badass (with the twin turbos). Did you get yelled at for posting pics?
Cab off is definitely a turn on............ In the long run being able to do a job comfortably often means doing higher quality work![]()
The trans fluid is checked in the same place you drain it. The little plug inside the big plug on the bottom, is how its done. At operating temp, remove the small plug while running. The fluid should dribble out.I hate it myself. No way can the average person work on their own vehicles anymore. That is the goal of all the major automotive manufacturers. Stop shade tree mechanics and even professional mechanics who do not work for them. All the computer garbage is not helping either.
You eight take your vehicle to ford, or send it to the salvage Yard. Not a way to earn business.
The (newer than mine) explorers you can't even check your own transmission fluid. How stupid is that?
Um......you don't have to pull the cab to service the engine.I hate to say it, but having to pull the cab to service that engine is PI$$ poor engineering!!!
