Sparky83
Virginia Chapter member
Looking for some old school Electrical Ignition help.. (ie pre-computer controlled stuff).. Working on a small twin cylinder 4 cycle engine that used the "Waste Spark" setup for the ignition (where both cylinders fired every time whether it was exhaust or compression stroke). I think the coil pack thats on the engines gone as itll run for 2 minutes and die.. you can smell its getting gas.. let it sit for an hr.. itll fire up again and do it all over again...
Bad thing is the mfg discontinued the coil and now they want 2 arms and a leg for the replacement... which i dont feel like paying that much for.. So figured id try going old school and wiring 2 canister coils together to serv the same purpose.. the downside is i wont be able to use their ignition module either.. having to work around it too (iow removing it for my own)..
Excuse my crude electrical drawing.. im not a Picasso...
So was wondering if this would work for getting both coils to fire at the same time? this diagrams showing them wired in series.. but was also thought about wiring them in paralleled.. but not sure which would work better for what i need it to do..
