Ton van der Sluijs
official Lucas dealer
Goodmorning everybody.
I was thinking about the position of my airfilter... Original Ford has placed it on the very left side, connected with long hoses... Because I do have an LPG injection, I do have a K&N filter straight at the throttle box... When my engine is at temperature, the ride is fine.. when in front of a trafficlight it nearly stalls after two minutes or so.. In the lowermaanifold is a inlet air temp sensor situated... when standing still at idle or engine shut down for a couple of minutes, The incoming air shall be very hot... Is it possible that the computer adjust it's fuel to that hot incoming air for a minute, thus that thhe mix is completely leaned out?
I would like it if on of you would be so kind to advice me.. common sense says to me, that the bloke who placed the LPG , made a mistake. for the Ampco LPG's a long hose is brought as fas as possible to the front to get fresh, cold air.
best regards Ton
best regards Ton
