89frankenford
Grabber Green Consultant
ok so i had a massive exhaust leak on my truck. one of my manifold downpipes was completely broken off right before the O2 sensor. which would explain my backfiring issue, lack of power, huge fuel consumption and really loud exhaust. so i welded up the exhaust on saturday and now i have a random off and on check engine light. so i did the self test KOEO and KOER. i messed up the KOER test at the beginning but i figured it out after a few seconds. i revved it up to 3K and the test began. and oh what a sight..... well here it is. i will definitely need some help with this one.
KOEO
21 ECT out of self test range 0.3 to 3.7 volts.
24 ACT sensor out of self test range 0.3 to 3.7 volts.
67 Neutral safety circuit failure.
84 EGR Vacuum Solenoid circuit failure.
13 Cannot control RPM during ER Self-Test low RPM check.
34 PFE or EVP circuit above the closed limit of 0.67 volts.
KOER
23 Closed throttle TPS voltage higher or lower than expected.
41 No HEGO switching detected always lean (right side).
33 EGR valve opening not detected.
73 TPS senor did not exceed 25% rotation during Dynamic Response Test (user error).
25 Knock not sensed during dynamic test.
KOEO
KOER
![Confused [confused] [confused]](/old/forum/images/smilies/confused0082.gif)
