Oil sensor?
Hey all! Not sure if I'm having an oil sensor or oil gauge problem. When I start my truck, the gauge reads about normal. After a while it slowly drops to Low. Any thoughts on what it might be?
Only way to be sure is to get a mechanical gauge on it and verify. It could be that you have excessive clearances that once the oil warms up shows to be an issue when the oil thins down from being heated.
I'm guessing what Roger said, I've seen it before on my own trucks.
Thanks guys, I'll try to get a mechanical gauge on it soon. What weight of oil do you all typically run? I'm in the Pacific Northwest and am using 10W30 high mileage. Should I switch?
